Wadia x64.4 sledgehammer output stage problem
Old 13th September 2020, 11:23 AM   #11
RobertS61 is offline RobertS61  Netherlands
These you mean?:
https://www.diyaudio.com/forums/atta...1&d=1599996176
HA5002:
https://www.diyaudio.com/forums/atta...1&d=1599996663
and the other two not pointed to.
File Type: jpg Wadia 2000 earlier output - opamps.jpg (662.9 KB, 56 views)
Old 13th September 2020, 12:08 PM   #12
diyiggy is offline diyiggy
diyiggy's Avatar
Are rhe little yellow caps at the top of the pictures some decoupling wet tantal ? Shorts?
Or manufacturing problem if a common issue whatever the design...I m thinking about cold joints...?!
Are the red units on both boards some relays that need checking as well?
Old 13th September 2020, 02:09 PM   #13
To be honest I've no idea.
Those yellow/brown look like tantals (I have no schematic) and those red like indeed like relays that would be worth investing.
My primary question was if I could swap out the boards from the non-sledgehammer outputs with the sledgehammer output boards of my newer working DAC after I made sure all the voltages are alright, connectors etc...
If I swap those outputboards and the unit is working, I know that the right outputboard is the culprit that causes no output in that channel.
Old 13th September 2020, 03:30 PM   #14
Default HA5002
Originally Posted by madskaman View Post
I was actually able to fix this board after a while. Ended up being the opamp on one channel after all that. Ha5002 I believe.
Wher did you source that metal can round opamp?
Seems obsolete..
Only available on Ebay
Old 13th September 2020, 03:50 PM   #15
madskaman is offline madskaman  United States
Correct. The painted black cans are opamps. I replaced the bad one with HA2-5002. And yes, had to roll the dice on eBay.
Old 13th September 2020, 07:19 PM   #16
Default HA-5002
Okay, clear.
I will investigate first if it is the outputboard and then I will try to investigate further.
How did you find the faulty one?
Old 14th September 2020, 07:30 PM   #17
I would probably just unsolder the opamps on the bad channel and swap them. If it is a bad opamp, then you would have a similar symptom with xlr (low gain) but your rca would output correctly.
You could check voltages and signal before... but if it's playing from the xlr, then voltages are likely good. You could check to see if you have signal at the input to the opamp. I checked mine with a dmm, ac voltage at pin 8. I had something like .6v with it "playing" and nothing on the output. If you have no signal on the input, then that would point to a relay upstream preventing signal to pass through.
Old 14th September 2020, 07:49 PM   #18
The XLR plays at a low volume indeed.
So just swap the two HA2-5002 opamps in my faulty channel you advise?
All the DC voltages are okay.
Old 15th September 2020, 02:23 PM   #19
Default Wadia 2000 ouputboard
These is the Wadia 2000 year 1990 version outputboard:
Leftchannel working:
https://www.diyaudio.com/forums/atta...1&d=1600179335
Rightchannel dead on RCA low level on XLR:
https://www.diyaudio.com/forums/atta...1&d=1600179341
Soldersite of the Left- and Rightchannel:
With a black marker a OK with date and paragraph is written on this site at 1-9-90 being probably an American dateformat meaning the January 9 1990.
It's a bit tricky to get this board out.
There's almost no grip on the RCA nuts at the back and the 6 hexscrews are tightened with 100 lbs torque so I needed to extent the key to get them loose. One slip and you're done...
I think I lack to proper soldering skills to get these HA2-5002 opamps desoldered so I let a more experienced friend of mine desolder them.
I ordered 4 in Hong Kong and hope at least two are good...
File Type: jpg Wadia 2000 Outputboard leftchannel .jpg (841.3 KB, 25 views)
File Type: jpg Wadia 2000 Outputboard rightchannel .jpg (884.7 KB, 25 views)
Old 15th September 2020, 03:14 PM   #20
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
These, being diamond buffers with no voltage gain should be easy enough to troubleshoot even without a scope. Just take them out and jumper IN to OUT.
It may even sound better that way.
Wadia x64.4 sledgehammer output stage problemHide this!Advertise here!
Sledgehammer to crack a Lightspeed walnut number7 Solid State 21 21st October 2016 10:02 PM
CR Kalypso Amp with output stage problem- Please help! Andyroid Tubes / Valves 3 25th January 2014 10:12 AM
Common emitter stage driving low hfe output stage Fusion916 Solid State 1 20th December 2012 05:05 PM
Analog stage WADIA XXX Digital Source 0 29th January 2007 02:20 PM
Mismatched drivers in output stage - is this a problem? Dave S Solid State 17 29th November 2005 09:30 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
