Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Thread Tools |
#8281 |
Yes, Doede know what he’s doing, no doubt.
#8282 |
DDDAC Audio
off topic....
![]() new thread started with a poll for my blog site would appreciate your inputs (sorry no prizes to be won ![]() New Thread LINK |
#8283 |
Not even a small prize such as a fully built DDDAC with all the bells and whistles??
#8284 | |
Normally there are 7810 regulators that need around 12 volt to be able to supply 10 volt to the Tent shunts. There have been people here skipping these regulators and supply something close to 10 volt to get a better sound they said. All these multi F caps contain loads of energy and i am not sure if they will " drain " completely after other parts of your digital set_up already ran out of juice so to say. You NEED to be sure what you are doing when using these caps. Usually if something goes wrong it will go wrong terribly because there is a lot of current available. Of course these caps need to be securely attached to the chassis and not the typical diy way using some kind of glue. Of course some planes are partially being glued but they are using exactly the right glue and use it the right way! If you go to a big diy store you can find the right glue probably. BUT i know from my former job that most glues only work with the right preparations. Some glues we used would only work with a special primer. We had to do several test for a special application and just one of the glues would stick after being summited to some force in the first month. Just imagine that a badly glued supercap would roll around your chassis after being moved around to audiophile friends by UPS. A true firecracker. Greetings,Eduard |
#8285 |
So the next phase of my DDDAC journey begins! Further PSU improvements
#8286 | |
https://www.mouser.de/Passive-Compon...z0yhcsZ1z0j00b Problem solved.
Preferred BSC? Just using a wide enough baffle. |
#8287 |
DDDAC Audio
Nice Simon, would you publish a small sketch how your going to hook up things?
#8288 |
I sure will Doede once it’s all completed
#8289 |
It's a very good PSU for DDDAC, especially if two rails are paralleled, but I advise to use it with caution, especially in a test environment.
IMG_1949.JPG If your batteries somehow discharge below their critical level, an internal short can occur. I experienced this with DDDAC and this PSU. After that, I tested two A123 batteries under controlled circumstances. They do not tend to explode, but they heat to about 220-250 degrees, also they produce smoke and hot electrolyte will leak to the board. In my point of view, several actions needed to made this configuration with DDDAC safe: 1. board is completely covered by heat-resistant varnish (did it). 2. board is completely covered by high temp polyimide foil (did it) 3. battery holders are made of high temp plastic, not ABS (I printed them on my 3D printer, filament -- PC). 4. thermal sensor is placed on the top of each battery (bought all parts, not completed yet). 5. required turn-off time is carefully measured. |
#8290 |
Thank you for the tips.
Do you power the Dac with your psu? I won’t be doing that and plan to power only the FiFoPi and Andres clock which are all low power |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
FS: Audio Widget (modified) Async USB DAC 24/192 ESS 9023 headphone friendly ASIO KS | 2A3SET | Swap Meet | 5 | 15th August 2012 05:52 AM |
Show my PCM1794 DAC TSOLINK + COAX + USB input, Line and headphone AMP output | AWaudio | Vendor's Bazaar | 3 | 2nd January 2012 01:44 PM |
GodDAC - 192/24 USB DAC | BizonGod | Digital Source | 36 | 30th June 2011 04:16 PM |
24 bit/192 kHz via USB? | gentlevoice | Everything Else | 3 | 22nd December 2008 07:24 AM |
New To Site? | Need Help? |
