Differential output DACs, can I use only one output.
Thread Tools
Old 17th June 2011, 02:45 AM   #1
oon_the_kid is offline oon_the_kid  Malaysia
oon_the_kid's Avatar
Default Differential output DACs, can I use only one output.
I have a AD1853 DAC differential output current DAC. Can I check if it is okay to use only one of the current output instead of both the outputs as a single ended output DAC?
Thanks.
Oon
Old 18th June 2011, 06:32 AM   #2
esangenisd is offline esangenisd  Mexico
I use only one ouput i+ r+ to a resistor to a srpp and is playing music really nice. The bad thing is that i only get 2 miliamps at output and not 4 ma in differential.
Old 18th June 2011, 06:57 AM   #3
abraxalito is online now abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
That's an interesting point yeah. It makes me wonder if we couldn't use the other channel in an interesting way to get back to the 4mA again. Just thinking aloud here, don't know if this will work but have you heard of mid-side format for stereo?
I know everything you know about this times 1000 - Amir @ ASR
Old 20th June 2011, 06:29 PM   #4
qusp is offline qusp  Australia
qusp's Avatar
wouldnt you just use some form of instrumentation amp to get SE output using all of the DNR?
Old 20th June 2011, 08:05 PM   #5
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
Yes, you can, one caveat, make sure you load both outputs equally, also, you may have to return the I/V resistor to Vref, not ground to make sure the DAC works correctly.
Ciao T
Old 21st June 2011, 05:13 PM   #6
What do you mean load the output equally? How would you do that?
Oon
Sent from my Milestone using Tapatalk
Old 21st June 2011, 06:08 PM   #7
Sorry, I spoke out of turn, never mind.
Ciao T
Old 25th June 2011, 06:09 PM   #8
Huh, what do you mean spoke out of turn? Not sure what you mean by that, but an apology is definitely not needed. How did you say I should load them equally?
Oon
Old 25th June 2011, 10:10 PM   #9
TV Man is offline TV Man
oon,
I believe what Thorsten meant was to make sure to use the same impednace on both the + and - outputs of your DAC chip. If you're taking signal from the + line and it's loaded with 3k ohms for example also put 3k ohms across the - output even if you don't take any signal from there. The DAC chip will work best with equal resistance on both output phases.
Old 28th June 2011, 12:13 PM   #10
Ok, that makes sense, so if I use it on a normal op amp based I/V stage with a voltage at 2.5V, I would then connect the other ouput differential to a 2.5V source as well... correct...?
Oon
Differential output DACs, can I use only one output.Hide this!Advertise here!
Thread Tools
Zapfilter2 and current-output dacs Glenn2 Digital Line Level 5 31st October 2016 08:36 AM
Differential output Keruskerfuerst Analogue Source 3 18th July 2007 01:25 AM
Using differential amps for output I/V? ezkcdude Digital Source 3 27th April 2006 09:43 PM
any info. anywhere on output stages for dacs? lt cdr data Digital Source 3 21st May 2005 05:18 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
