Unable to get foo_dsp_xover working
Unable to get foo_dsp_xover working Please consider donating to help us continue to serve you.
Old 14th June 2009, 07:52 PM   #1
goldyrathore is offline goldyrathore  India
Default Unable to get foo_dsp_xover working
I am trying to setup a 2 way digital xover for which I am using foobar with the crossover foo_dsp_xover plugin.
But I dont get sound on any output other than FRONTLEFT and FRONTRIGHT. The SURROUNDLEFT, SURROUNDRIGHT, CENTER and LFE are completely quiet for reasons not clear.
However, when I tested the Low filter output thru FRONTS , I found it to be working fine.
Similarly when I tested the High filter output thru FRONTS , I found it to be working fine too. So the conclusion was: the other outputs are not working fine. All the 5.1 channel outputs work fine individually when tested with the sound card's control panel .
I am using the onboard SigmaTel soundcard. Can somebody help me?
Old 15th June 2009, 05:47 AM   #2
Key is offline Key  United States
File>Preferences>Output>ASIO virtual devices> edit the card you use to the correct outputs.
You have to have the ASIO component of course. If not choose primary sound card or something like that.
Old 28th June 2009, 12:28 PM   #3
I did that, but still no success.
However, I got it working after the following steps
1) Go to Control Panel->'Sounds And Audio Devices'. 'Sounds And Audio Devices' dialog appears.
2) Select Volume Tab. Click 'Advanced' button under 'Speaker Settings'. 'Advanced Audio Properties' dialog appears.
3) In 'Speakers' tab, select '5.1 Surround speakers' and click apply.
Hope it helps others
Unable to get foo_dsp_xover workingHide this!Advertise here!
Unable to post Russellc Forum Problems 10 18th December 2018 03:13 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
