Filter choke orientation
Working on a layout for a build. I understand that power transformers and output transformers need to be oriented at 90 degree angles to each other. This design uses a choke and my question is how should the choke oriented? I was planning mount the choke under the chassis and the power and output transformers on top. Thanks in advance
