Unity gain output stage Class D driver
Thread Tools
Old 22nd July 2021, 10:16 AM   #11
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Тhis would perhaps be interesting if Devialet amps actually sounded any good... Lifestyle audio.
Old 22nd July 2021, 09:10 PM   #12
ubergeeknz is offline ubergeeknz  New Zealand
Originally Posted by steveu View Post
It is difficult to say exactly what Devialet are doing but I suspect it is similar to the Yamaha hybrid amplifier where the power supply rails are switch-mode controlled so that the analog output devices operate with a maximum of about 4 Volts drop and therefore very little heat is wasted. In any case, the class-D outputs are not tacked on the output of an analog amplifier, but perhaps the other way around so that the analog amplifier dictates the final result.
Their video talks about the Class-D and Class-A amplifiers running in parallel, but who knows if that's how it actually works. They claim to have it patented, so one could always look up the patent for a clearer description.
Either way, I don't think it's the kind of thing most hobbyists could knock up from scratch.
Old 22nd July 2021, 09:11 PM   #13
Shots fired eh
  Reply to this post
Unity gain output stage Class D driverHide this!Advertise here!
Thread Tools
Transformer based voltage gain + unity gain stage? soundcheck Solid State 2 10th August 2010 02:44 PM
heretical unity gain OUTPUT stage... andrew_whitham Tubes / Valves 4 9th December 2006 03:36 AM
Heretical Unity Gain line stage PLUS a little gain ? yagas Tubes / Valves 7 24th January 2006 01:30 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
unity gain push pull output stage ergo Solid State 11 6th January 2003 10:32 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
