Pascal x-Pro Modul clipping with 4V output
Old 26th November 2019, 08:55 PM   #1
Dominik H is offline Dominik H  Germany
Default Pascal x-Pro Modul clipping with 4V output
Hello I own a Pascal X-Pro1 modul which is limiting the speaker output to 4V.
If i try to get more out of it , I get a clipping signal at the output.
Up to 4 V Output voltage raises normaly, than the clipping led starts to light an the sine wave on the output gets deformed.
I have a second one which is working properly in the same Setup.
I have checked the four transistors of the output stage and checked the +90V -90V rail, also checked the +15 -15V , everything seems to be ok.
Does anyone have any Idea where else i can search for a defect?
Does any one have a schematic for the modul?
Old 27th November 2019, 06:57 PM   #2
KaffiMann is offline KaffiMann  Norway
Fanatic
KaffiMann's Avatar
I would just try and send an email to pascal. They where very polite when I had some questions.
Things are starting to happen, work in progress: https://kaffimann.com
Old 28th November 2019, 05:07 AM   #3
Turbowatch2 is offline Turbowatch2  Germany
What Kind of load do you have? Open Output is not good. Is it in SE or bridged configuration?
Where do you connect ground?
Old 28th November 2019, 05:33 AM   #4
I used an 8R Load.
The X-Pro1 only has the 2500W Output, this should be a bridged Output.
Grounded only through the main plug wiring.
Atached the pics from the good and the bad modul.
Both at the exact same Setup, only the signal-input voltage of the second one was reduced.
Old 28th November 2019, 12:55 PM   #5
Emailed them, but no support from them for customers, only for oem buyng big numbers.
Old 28th November 2019, 11:40 PM   #6
If you have two, one working, one not, you can walk trough the whole cirquit until you find differences. This is how repair technicians have been working for the last thousand years.
While repair in ancient times was always an option, today one must accept that most stuff is NOT made for any repair. Check fuse, if still not work, throw away, done.
Old 29th November 2019, 06:43 AM   #7
Yeah,, I know about that option, but it takes a lot of time because I have no clue where to start the search.
Electronics isn´t my favourite.
I know how to use the measurement tools, but walking through whole the circuit will be a pain for me, I know only a little about class D designs.
Fuse checked
Will probably end with throw away.
Old 29th November 2019, 07:25 AM   #8
Fanatic
KaffiMann's Avatar
Yeah, more or less the same response I got, except I had a very different question.
Have you checked if there is something wrong with the "Amplifier Output Voltage readout" or "Amplifier Clip readout" pins?
Something wrong with these might cause "Dis_Read/Protect– This readout is an open-collector output which will be pulled low when the module is either muted or has entered an internal protection." In which case you can measure it and figure out the general part of the board where the problem is.
Other than that I'm not much help.
Protection features from page 21 onwards:
https://www.pascal-audio.com/wp-cont..._Sheet-2_6.pdf
Pascal x-Pro Modul clipping with 4V outputHide this!Advertise here!
Firstwatt B5 max output and clipping VuGiaA9 Pass Labs 4 26th July 2018 01:56 AM
JL Audio 500/1 low output and clipping KevinMangini Car Audio 8 19th October 2017 02:18 AM
No input signal yet still getting output? and clipping singaporerock Solid State 6 6th January 2016 12:53 AM
Punch 200DSM output clipping 17DoubleE Car Audio 4 16th October 2009 01:30 AM
PC sound output clipping problem hajame Digital Source 3 29th April 2008 05:39 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
