Hfi1500d help
I'm looking at the 81013 v1.0 driver board and would like to know what the part numbers are for the ic chips that are on it.
If by "regulators" you mean the SOT223-packaged devices in the top left, they're "only" high-voltage transistors (as per the P2D marking).
https://www.onsemi.com/pub/Collateral/PZTA92T1-D.PDF
"30 volts on the op amps" = between pins 4 and 8, or..?
Oh, sorry the regulators on the main board and yes at pin 4 and 8. I believe those regulators supply the op amps, from how it looks anyway.
