Mysterhawk, is this an existing kit that you are modifying, with box and all, or a board that you modified and added a box to?
It is this is a stock DollaTek Breeze Mini Dual TPA3116 amplifier:Mysterhawk, is this an existing kit that you are modifying, with box and all, or a board that you modified and added a box to?
I've bought locally from Amazon:
https://www.amazon.it//dp/B07KPSYHWF
The pcb is that one that you will find inside the amp 🙂
It was about 30 EUR at the time 🙂
I can confirm that after the upgrades, it runs a lot warmer, but it sounds nice too :^]
Since the upgrade ~20 days have passed
I listened to CS8673 amps, similar power like TPA3116. And they do well.
Checked the data sheets and distortion looked even better.
https://www.diyaudio.com/community/threads/difference-between-cs8673-and-tpa3116.405281/
Got some of these amps for outdoor purpose for 4 euro instead of 15€.
Like Whuzi Audio Zk MT502
@Freedom666 would you share some photos about these boards or where you could buy them?
I'm curious 👀
I'm curious 👀
zk mt 502
zk mt21
zk tb21
are from whuzi audio on aliexpress
listened to them against tda2003 converted to current drive
just search after zk mt in the forum
https://www.diyaudio.com/community/threads/unboxing-zk-mt21-tpa3116.403857/#post-7518041
zk mt21
zk tb21
Ah yes, I saw those models, I wasn't totally convince by the choice of the PCB case, so I didn't choose them XDzk mt 502
zk mt21
zk tb21
- Class D
- New Breeeze Audio TPA3116 2.0 100W dual chip
