Hey Peoples,
"Your success and happiness lies in your own hands. So be optimistic and happy yourself and you shall see you are able to fight any kind of hostilities. Happy New Year!"...
I am planning to build an amplifier for my car,Basically I wanted to build an amlifier for the Subwoofer so I have two choices,
1) TI TPA3255 based amplifier
2) Elliot based amplifier 300/500W Subwoofer Power Amplifier
Both the amp's PCB and Electronics will be build by me (Designed, fabricated and Tested)
Your Suggestions are welcome
1.if you like old fashion, just try Elliot based amplifier
-pCB desing is easy and simple circuit
-little bit complex to fix errors
-need split power supply,smps desing is complex sometimes
-cost more (4X) than class D desings
-need large heatsink or +fan to cooldown
-inefficient
-inefficient
Thanks for your Ideas,I do like the TPA3255,It has such a small foot print that I can Pack 400w RMS into a 50mm x 50mm Design,For which I am Deciding to build the amplifier and Give those ready-made or PCB for low prices to interested people.
I am thinking of an Class D Car Amplifier and a Home Based Powered Subwoofer Amplifier.
this my desing
home made PCB TDA7498
diysmps)
http://www.diysmps.com/forums/showthread.php?498-TDA7498-100W-100w-Diy-(u-PCB-power-supply)
diysmps)
I'm very interested in seeing continuous 400Wrms in 50*50mm.
Tap into the freon tube for the air conditioner of the car?
- Class D
- TPA3255 Amplifier for Car Audio System
