ICEPower 500A Evaluation Module Question
Joined 2005
Hello all,
I have an ICEPower Evaluation Module that comes without SMPS, but with caps and rectifier for a Linear Power supply (just add your transformer). There is an AC Input connector that is same type of connector used for the 500A Voltage power rail and speaker outs.
There are 8 pins, and looking at the connector, the top left pair of pins go to AC on rectifier, and kitty corner to these is another pair of pins that connect to the other AC connection of rectifier. This is where I will put the 0V - 50VAC transformer winding to make the 72VDC rail. The pair just below the power connection are common and connect to the PS ground pins on caps and audio ground.
Now the other pair to the side of power connectors are not "shared", and I think they should be for 12VAC and 12VAC transformer connections (me thinks) that make up the +/-15VDC. I cannot trace these as they disappear under the modules...
Can anyone confirm these connections?? Don't wanna blow these up...
Joined 2005
This is what I believe the connections should be...
Joined 2005
Yes, thanks - I should have made myself more clear - I have built tons of ICEPower amps - ones with their own SMPS and regular amps based around the non powered amp modules (ie 500A) building a separate Linear Power Supply with 72VDC and +/-15VDC.
What I have is a ICEPower Evaluation Module that consists of two 500A modules on a larger PCB with PS caps, rectifiers, pair of XLR Jacks and Neutrik Speakon speaker out connections.. This evaluation Module has an AC Input Connector that allows the connection of a transformer (all other components of a linear power supply are already on the board).
These modules do not come up that often. See pic (not mine - from another member here that posted these for sale years ago)
The ones in front of pic are like the evaluation modules I have. This was a pic from a member here years ago that sold his modules. The evl modules in front are the (dual) 500A and ones in back are (singular) 1000A...
The single square steel object in middle of 500A eval module is the heat sink fitted over the main PS rectifier for the Vp. Behind it is the AC Connector. I have not yet found the rectifier for the +/- 15VDC from tracing the board...
At first sight I thought these were made for subwoofer use maybe? But why two channel? I hope the PCB circuits do not have frequency limitations limiting the Eval module for subwoodfer duty only, like the 1000A modules (amplify to 3khz only). I have removed the actual 500A modules and compared them to regular 500A modules and look fine...but was hoping to build an amp by just adding tranny - like a Henry Ho H20 Amp (500A based amp with Class A Linear power Supply)...
I am just too lazy to get my camera to take the pic. New years res to be less lazy.
Joined 2005
OK, I got the voltages correct - my previous post was incorrect - just the mirror image of what I posted - confirmed by the voltages at the alternate connections on side (+15V GrndA -15V and Vp - Grndp)
Anyway, looks like the modules are still not working - the Vp is getting to the modules, but the 15VDC -0 - -15VDC are not getting to module - the external control connection header probably needs a trigger to allow these to connect to the module....
No one has the pinout connections for the external control pinouts?
Joined 2005
Ha! I finally got it. The slow ramp up to 70VDC and +/- 12VDC on variac was preventing the system from completely turniing on. Once I left variac at 120VAC and switched power on, the whole system started up perfectly.
And just in case anyone was still interested, the correct AC pinout on unit is now corrected, and also a pic of where the rectifier for Vp and AC connector is
Joined 2005
Hello Nisbeth,
On the I/O Control pinout on the Eval board, do you know which pins need to be pulled down (connected to ground) to put modules in Standby? The SW1/2 or control1/2?
Only thing left to do, amp works great!
Hi John,
Haven't played with these in a (long) while, but if i'm reading the schematic correctly then sw1/sw2 are for the control signals to the module whereas the control1/control2 connections are for the control pins (if you want to read the module status using an external circuit). The attached snip from the A-series app. note might help explain my conclusion :D
/U.
PS: What do you think about the sound?
Joined 2005
I re-read that diagram from eval module manual-
I connected together the two SW pins (pin 5 and pin 6) so both channels go into standby together. When I connect the +12v pin (pin 1) to the connected sw1/sw2 pins the modules successfully go into standby. But when I break that connection, amp remains in standby, and I need to reconnect the +12 and sw pins for the standby to go off. Looks like I need a momentary switch
Joined 2005
I wonder if I can just use a regular switch, and flip it on / off - to activate / deactivate standby (mimick a momentary). Cant see any harm, unless I leave in middle - I could be bypassing the protection circuitry...as it is connected with the standby circuitry...
