ICEPower 500A Evaluation Module Question
Thread Tools
Old 15th January 2016, 07:34 PM   #11
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
https://dl.dropboxusercontent.com/u/...d_Note_1-1.pdf
/U.
DIY projects blog
Old 15th January 2016, 08:21 PM   #12
john65b is offline john65b  United States
john65b's Avatar
Thanks ! I will have to take a look at it.
I Speak Spanish to God, Italian to Women, French to Men, and German to My Horse. Charles V
Old 30th January 2016, 05:07 PM   #13
john65b's Avatar
Hello Nisbeth,
On the I/O Control pinout on the Eval board, do you know which pins need to be pulled down (connected to ground) to put modules in Standby? The SW1/2 or control1/2?
Only thing left to do, amp works great!
Old 30th January 2016, 07:44 PM   #14
Nisbeth's Avatar
Hi John,
Haven't played with these in a (long) while, but if i'm reading the schematic correctly then sw1/sw2 are for the control signals to the module whereas the control1/control2 connections are for the control pins (if you want to read the module status using an external circuit). The attached snip from the A-series app. note might help explain my conclusion
/U.
PS: What do you think about the sound?
DIY projects blog
Old 30th January 2016, 07:53 PM   #15
john65b's Avatar
I re-read that diagram from eval module manual-
I connected together the two SW pins (pin 5 and pin 6) so both channels go into standby together. When I connect the +12v pin (pin 1) to the connected sw1/sw2 pins the modules successfully go into standby. But when I break that connection, amp remains in standby, and I need to reconnect the +12 and sw pins for the standby to go off. Looks like I need a momentary switch
Old 30th January 2016, 08:07 PM   #16
Nisbeth's Avatar
I think that's right. The supporting circuitry on the eval. board is (as I recall) a flip-flop that toggles with each press of the onboard switch (so an external switch would behave the same way). If you only had the module itself, you'd need a latching switch to hold the control pin in low-state in order to put the module in standby.
/U.
DIY projects blog
Old 30th January 2016, 08:20 PM   #17
john65b's Avatar
I wonder if I can just use a regular switch, and flip it on / off - to activate / deactivate standby (mimick a momentary). Cant see any harm, unless I leave in middle - I could be bypassing the protection circuitry...as it is connected with the standby circuitry...
  Reply to this post
ICEPower 500A Evaluation Module QuestionHide this!Advertise here!
Thread Tools
ICEPower 500A modules john65b Swap Meet 2 8th November 2015 01:42 PM
For sale: ICEpower 500A Modules Stanray Swap Meet 6 20th April 2015 10:23 AM
ICEPower 500A Modules john65b Swap Meet 8 8th December 2011 02:43 AM
WTB : ICEPower 500A module YCLee Swap Meet 3 15th October 2009 01:53 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
