TDA7294 Power Amp, 120Wrms
This is my first post!!
Thank you all in diyaudio, many times you've solved my questions. Now it's my time to post mine here.
So I'm trying to make a modular preamp and power amp, the preamp cranked up outputs 1.1V peak (0dbu), and I want to make this signal to go 120Wrms (8 Ohms) using some power amp IC (I've chosen the TDA7294 cause I kinda know its datasheet but if you like another one better, tell me!)
I've made my research and I think that making a brigde setup +/-24Vcc, 40 linear gain, 29dB ,I should be able to get to this level. But what if I use the FX return? Then I could go much higher and then I risk blowing up my speakers.
Can anyone give me some advice? Thank you all in advance
ps. Cabinet I plan on using: Harley Benton G212 Vintage Vertical – Thomann Espana
I think I've found a solution?!
Supplying this bridged amp with +/- 22V limits the maximum output at 120W at a 8Ohm load as specified in the datasheet, and using the 80-120W range I can get a range of harmonic distortions. If you go further than 120W the amp just clips (I think?)
chermann;6665190 22Vrms means about 31Vpeak Voltage and if you calculate a drop of your supply of about 3-4Volt--> means you need about 35V at your amp boards. as far i remember... like the LM3886 the limit for 4R using is +/- 29V. chris[/QUOTE said:
I get it, but since I'm using a bridged setup, I should be able to get the 120W with such low voltage. But what you say about the voltage supply drop is something I didn't even thought about, so yeah now I see a stronger reason to follow this.
You can go upto +/-25vDC or maybe little more with large heatsink and 8ohm load. +/-25v is recommended by manufacturer.
Limiting power supply voltage should protect your speakers.
No, it doesn't !! Amp will clip earlier if pushed hard and clipping is what destroys speakers. Tweeters are the first ones to go. An heavy clipping amp for long time blows a speaker with more rated power.
The best protection is incorporating monitoring.
A Clip indicator or a VU tells You what levels You can go up. Even Your trained ears can do it. A DC fault circuit is also handy for catastrophic failures.
I think of making a guitar amp so clipping should be an usual thing to deal with
