hhiiiiiiii
i m looking for building a 120w power amp in 4 ohm load
this for a sub.
i plan to use 2 lm3886 in the bridged _parallel configguration
but i have one problem.
i don't handerstand how conect it to the speaker. circuit designs on the net contradict themself :
some conect one pin of the speaker to the output of the amp and the second to the ground.
And others conect each pin of the speaker to each output of the 2 chips.
and here im lost. does everyone could explain me the good way to act in that case..🙂 🙂
this for a sub.
audioloud said:hhiiiiiiii
this for a sub.
A bridged amp's output are ALWAYS the output of each amp, the one fed with the non-inverted input goes the speaker's positive and the one fed from the inverted output goes to the speaker's negative end.
If you wire a speaker between one of the amp's outputs and ground you are just using a single amp, not the bridge. If you wire different speakers to each amp you will be feeding out of phase signals to them and cause a quite strange sound effect. nulling most of the sound if they are close by.
Carlos
I think the confusion here is the difference between bridged and paralleled, if you build a bridged parallel LM3886 you need a minimum of 4 chips.
For a pair of parallel chips, you would basically just tie the outputs of to identical chips together and it would allow you to double the currant (good for a low resistance load like you have)
For bridged chips you tie the non-inverting output of one chip and the inverting output of another chip to each lead on a speaker. This gives you a higher potential for voltage and is better for a high resistance speaker (not good for your 4ohm unit)
For a 2 chip-amp amp I would suggest a parallel connection
You might also want to review AN-1192.pdf from National if you haven’t already
thomas997 said:Could someone post a circuit for what he is asking for?
I am interested as well.
thanks
Grab http://www.national.com/an/AN/AN-1192.pdf and check page 7.
officeboy said:
thanks
ok
now it's clear for me the difference between the two configuration
The pdf that you posted has a deep wealth of information.
4 chips to get a 200w power amp !ok
I'll use 2 in parallel only .
thanks to you all .if you have any advice ...tell me!
AUDIOLOUD
AUDIOLOUD
I currently own a paire of two tda7293
can i replace the two lm3886 by these amp in the paralel config?
I heard that tda is not good enough for bass.
It reduce them at hight power .and i need it for my subwoofer!
tell me what you think of this ...
please.😎
please.😎
officeboy said:I think the confusion here is the difference between bridged and paralleled, if you build a bridged parallel LM3886 you need a minimum of 4 chips.
Are bridged amp chips a better application than if paralleled.
I'm thinking yes because the non-inverted chip drives cone outward and inverted chip drives cone inward. Doing so, wouldn't the sound be more crisp (short and exact)?
Is my thinking correct here. Two parallel chips (LM3875) would handle 132 watts@8ohms. Two bridged chips (LM3875) would still handle 68 watts@8ohms.
How is bridged/parallel chips better application? Four bridged/paralleled chips (LM3875) would handle 132 watts@8ohms or ??? watts@4ohms. What else? My interest here is using best application for a WtmW with active crossover
Paralleling 3 LM3886 for a 4Ohm load should be enough for your power levels.
Have a look at the spreadsheet that calculates everything for you.
http://www.diyaudio.com/forums/showthread.php?threadid=19896&highlight=spreadsheet
- Chip Amps
- 2 lm3886 for 120w in 4ohm load
