Radio mod TDA7266 raspberry pi
Old 3rd May 2020, 08:04 PM   #1
Gundrum is offline Gundrum
Default Radio mod TDA7266 raspberry pi
I'm trying to modify a radio such that the output goes through some audio processing in a raspberry pi (using a usb audio dongle) before getting amplified.
The amp is TDA7266 but the radio is mono and uses only one channel.
I'm a beginner and I'm wondering what would be the best way to do this. Could I simply interrupt the signal right before it goes into the input pin on the TDA766? I.e. the signal would go USB-input -> RPI processing -> USB-output -> TDA7266 pin 4. I guess this would depend on the strength of the signal pre- and post-processing. I'm also a bit confused as to which ground reference I would be using in for the USB input this case.
As you can tell I'm a bit over my head - any tips would be much appreciated.
Radio mod TDA7266 raspberry piHide this!Advertise here!
FS: Vintage Sony Radio Retrofitted with Raspberry Pi, DAC, and Upgraded Speaker muddyboots Swap Meet 6 26th April 2017 03:03 PM
Remote based Raspberry Pi internet radio without HDMI display goldyrathore PC Based 2 5th December 2016 06:21 PM
Another Raspberry Pi Radio rpi PC Based 17 17th June 2015 02:29 PM
TDA7266 Havoxx Chip Amps 8 11th August 2011 12:27 AM
Buffer for TDA7266? jaste Chip Amps 7 2nd January 2009 06:33 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
