Hi, I've started a small semi portable bluetooth speaker build and I'm having a hard time figuring out the powering and charging scheme. I've read and searched like crazy for the last few weeks, but I've seen a number of conflicting comments.
First of all the speaker is a dayton RS100-04/ND16FA two way in 1.7L that ends up at about 83db sensitivity after the xo. It's just one speaker so I will try to feed it a mono signal.
The items that I've purchased for it so far are a separate BT 4.0 module and a couple of little mono amp modules that use the TDA203A. I also ordered an integrated BT 4.0 and 25+25 watt amp module that uses the TDA7294P. I'd only use one of course, but I didn't know what to expect as far as the quality and functionality of the BT modules and also if I'd have ground loop issues if using a single power supply with separate modules.
I pickup up a 9.6V Nimh 2000mah Tenergy battery and accompaning wall charger that is 12v 400ma. This battery and power supply exceeds the minimum power requirements for all the boards and doesn't exceed any of the max voltage/amp ratings.
I also have a variety of plugs, rocker switches, barrel jacks and female DC jacks with 3 pin connections.
The issue I'm having is if I can connect the battery and wall charger to the modules in parallel without safety or longevity issues? That way the unit can run from the battery and/or wall charger and also charge the battery when the current draw from the amp isn't too high. There will be a rocker switch to power on/off the units. I realize the wall charger is probably under rated, amp wise, but so far the little 2030a's seem to run fine from it after I eliminated the noise the supply was introducing. I could switch to a 12v 2A charger if needed. Everything hooks up and powers up fine when I've connected the battery and charger to the amp at the same time and the battery is also receiving charging voltage with the speaker playing at moderate levels.
What I don't understand is the potential problems with this setup. I'm worried that the charger will not properly read the batteries charge state because of the draw from the amp and will either continue charging it to overcharge and cause damage or danger. Or that it will limit current when the battery's fully charged and shut off the amp (this is a less concerning outcome).
I've tried to figure out a wiring scheme that could use the floating third pin of the female dc jack in conjunction with the unneeded third pin of the rocker switch to use battery with no wall power connected, use the wall power when connected and disconnect the battery and charge the battery when the rocker switch is in the off position, but I can't figure it out.
So, any help would be greatly appreciated. I'm completely new to using and charging batteries in any of my projects. And I apologize for the novel, but the more info the better!
all depends 12V at 400mA charger and the "audio load". The heavier the "audio load" is will use up the charger current 1st.
is the charger a smart charger? then you should be OK for max V at 3*4.2V.
Why not play it safe and move the battery around, unless your looking for an "audio UPS".
until then you could figure it out yourself with a couple of cheap DMMs.
start out with a discharged battery scenario, and monitor charger current and chart the voltage keeping an eye out for abs max limit.
next try a fully charged batt. and repeat. best to study up on the battery chemistries you have selected, lots of resources on the web.( the only warning I can give you is your series conn battery will need "balancing" for each cell at some point!) does your charger do that?
I reckon the only danger is slow to recharge batts depending on the load. and increased ripple and noise with charger connected.
Thanks Infinia. Some of your terminology is a little over my head, but I got most of it.....I think What's a DMM? Usually I know its a meter, but you said I'd need a couple? I have a Digital multi meter. And what's the ABS max limit?
I don't wan't to move the battery around because I want an all enclosed system if possible.
I don't know if the charger's a smart charger, but for the price I paid, I doubt it. This is what I have http://www.amazon.com/Tenergy-9-6V-Battery-Plug-n-Play-Charger/dp/B005ZKSSZO
I've read a number papers about the different batteries types. From what I understand, the Nimh are less efficient, but safer and somewhat less critical about charging than the LI batteries. That and lower price are why I decided to start there.
I did connect the battery, charger and amp in parallel and played a source at fairly high levels (for that little amp) for a couple of hours. Beginning voltage on the battery was 9.8v I believe and the voltage after a couple of hours was 11.4v. It's a 9.6v battery, but it was at around 11.8v when I received it and reviews said it gets close to 12v when fully charged. The battery and charger never got warm at all really.
I did monitor voltage at the amp, battery throughout, but I don' tknow what I I should be looking for. The Voltage at the battery when charging started at around 11.2v and ended up at 11.5v. The amp had similar numbers I believe. The amp was drawing .02ma and the battery was drawing .01ma.
Also I got some extra noise (EMI) with the charger connected, but after a ferrite core and backing off the gain on the amp very slightly it disappeared.
sorry I was mistaken your batteries for LiPo hobby packs. please research "care and feeding of AA NiMH batteries". here's a startMade with 8xAA 2000mAh TENERGY high capacity and high power NiMH Batteries
http://batteryuniversity.com/learn/article/charging_nickel_metal_hydride
well you do follow directions?Charging Directions: It will take 7 hours to fully charge this 2000mah battery pack -- manually unplug the unit after the 7 hour period.
I reckon if they aren't heating up that's good. Without knowledge and monitoring things I wouldn't expect much long term success for your set up. that's the tradeoff for an all-in-one sealed system.
IMO next time consider a 3 cell 18650 external pack for portability.
Yes, I actually do follow directions, thanks. I don't remember seeing what you posted as I bought the battery a while back. The package said follow directions, but there were none included. The directions aren't exactly going to outline how to wire up a bluetooth module, amp and implement charging anyways. I can plug the thing into the wall and unplug it when it's charged, that's why I didn't ask how to do that
It seems to me that there are more options than just connecting everything in parallel, that's what I'm asking for. Do I need an internal charging circuit, different wall charger. I don't really see how long term success is compromised by an all in one setup. Many, many commercial products are just that. You don't have to remove the battery to charge the unit. I'm hoping to understand how they do that.
A different battery isn't a problem if that's what's needed.
There is usually a smart charge circuit built into the unit or charger. You could have a look at TI's line of chemistry-specific charge IC's to investigate this further.
I might not be too concerned with simultaneous play-charge. Several use and performance questions would need answers.
you don't have a smart charger. the best ones are implemented inside the battery pack like on a laptop. yours is purely time based without even a simple timer shutoff, so its manual only. Laptops battery packs have built-in complex circuitry based on series connected cells, using combination hardware, software, and balancing each cell, etc,) Charge time is estimated by the amount of discharge and the condition of the cells. So on yours, with brand new cells completely discharged and all the current available ( not running extra stuff ) it's 7 hrs. This time is adjusted for mAH and current so YOU cant run it in parallel with your extra stuff running and expect predictable charging or good lifetime. As the battery wears out the time is adjusted down due to decreased capacity. They talk about this in the link I gave you , did you read it? If you leave everthing in parallel like you want its likely to ruin your batt. pack in a year or less.
my advice, select good power supply with a DC plug then add the same plug on your battery pack and use either one, one at a time. then when the battery pack is discharged unplug it and use the supplied cheap charger according to the directions.
you may be able to use 2 switches or a multi pole switch to charge an internal battery and disconnect the audio.
but IMO all that buys you is using the same crappy charger to run the audio or charge the battery, but not at the same time.
Sorry but a good charger scheme for series connected cells and running your stuff is probably more complex than your entire project.
That was my thinking too. The charger does have a red light when charging that turns green when it's charged so that would imply some level of monitoring to me. Part of my confusion is that I don't know if the draw from the amp and BT module will confuse the monitoring built into the charger.
Now that i have actually hooked everything up, I think that a battery with it's own protection circuit would be the safer way to go. That way it's self regulated. Something like the Li-ion that infinia recommended.
As for use and performance questions. What do you need to know? The amps and BT boards all accept PS between 7-15v. The amps are fairly low powered and the speaker is fairly insensitive, but sims show xmax is exceeded with only about 7 watts so I figure 15-25W music power should be about right. I'm really only looking for maybe 88-90db max in room.
Run time: I'm hoping for a least 6-8 hours at normal listing levels.
I've noticed with the little 2030A boards that distortion sets in pretty fast at higher volume. Doesn't matter if it's running off the battery or 12v 2A supply. I even tried a 12v 5A supply and it's about the same. The same PS connected to a Lepai 2020a does much better with the speaker.
Maybe I need to add some capacitance in line with the supply? I'm very new to the electronics end of audio so please correct me if I'm wrong.
Anything else?
you don't have a smart charger. the best ones are (sort of complex circuitry based on series cells, software, and balancing etc,) implemented inside the battery pack like a laptop. yours is purely time based without even a simple timer shutoff, so its manual only. Time is estimated by the amount of discharge and the condition of the cells. So with brand new cells completely discharged and all the current available ( not running extra stuff ) it's 7 hrs. the time is adjusted for mAH and current so YOU cant run it in parallel with your extra stuff running and expect predictable charging or good lifetime. they talk about this in the link I gave you , did you read it?
Sorry but a good charger scheme for series connect cells and running your stuff is probably more complex than your entire project.
Understood. No I haven't gotten to it yet, but I will.
What about 12v 2A charger designed for 9.6v nimh batteries? Then using a switch scheme that uses the charger/PS to run the components with the battery out of the circuit and when the unit is turned off the charger connects to the battery? I guess I would still need to manually monitor and unplug it when it's charged.
so much industry push is towards those cells,
just 3 cells with more capacity than 2600 -3200 mAH , more protection, more charger options. look into them as replacements. I only buy Sony, Panasonic-Sanyo, Samsung, LG authentic grade. about $3/ICR cell and $5/IMR cell, ICR is better for one C or less drain. IMR is designed for higher drain like 2C and higher
Hi satx,
I've just briefly read through this thread so please pardon me if there's something I've missed ...
However, regarding batteries:
- NimH batteries typically are not easy to float charge, i.e. charge them continuously. They have very "small" signals indicating that they are fully charged so they are rarely continuously charged. I haven't heard of it actually.
Li-ion batteries may be float charged - I do so myself - and if they are kept at a maximum of 4.05 VDC per cell they should last for a long time. Mine have now been used for about 3/4 of a year - still appear to be fine and I hope they will last much longer.
They do, however, need balancing which is a circuit that makes sure that they don't e.g. distribute the voltages so that one battery ends up at 4.3 volts (will quickly ruin it) and another ends up at e.g. 3.8 volts. My batteries just slightly drifted before I implemented a balancing circuitry - I reckon such a circuitry is compulsory.
If I can make a suggestion then it would be to let go of Li-ion & the like (e.g. LiFePO4), NiMh, NiCd etc. and then instead get a sealed lead acid battery (SLA) like e.g. this one:
New 12V 5Ah SEALED Lead Acid SLA Battery for Alarm Systems UB1250 Home Security | eBay
SLA batteries are quite rugged and even accept reasonable overcharging. They are also very fine with float charging (=constant charging) at 13.5 - 13.8 VDC for a 12 VDC battery version.
You can e.g. use an LM317T to charge the battery. A circuitry like the attachment would work. If you replace the 240 ohm resistor with a 220 ohm resistor and use a 2200 ohm instead of the 1k1 ohm resistor then the output will be 13.75 VDC. You may also substitute a 5000 ohm (5k ohm) trimpot for the 1k1 ohm resistor - in this way you can adjust the output up to ~ 30 VDC. If you change the 1 ohm resistor to 0.6 ohms you will have a maximum output current of appr. 1 ampere.
Remember to put a fairly sized heatsink on the LM317T and also to have a minimum of 3 VDC higher input voltage than output voltage on the 317T.
If you keep heat dissipation from the LM317T below 3 watts ( (input voltage minus output voltage)*max current <= 3) then something like this could be used (will get warm though):
4X to 220 Heatsink Small Power Aluminum Heat Sink | eBay
If the heatsink will otherwise be in contact with the rest of the circuitry there should be an heat conductive isolator between the LM317T and the heatsink.
Hope this helps.
Best regards,
Jesper
Hope this helps.
Best regards,
Jesper
yes SLA is best for standby uses, UPS's and the like , but not for portability E.g energy density, or weight. very durable if not discharged too deeply.
Li don't like being at max charge for long periods in standby, that can kill them as much as too many cycles in the same period, in-fact best to store at nominal charge ~ 40-50% 3.7-3.8V / cell is the recommended for longest life. very good when under use ~ when average charge level over a period of time is reasonably closer to nominal.
IMO we don't really know the application of the OP concerning his best use case or charging pattern to recommend his ultimate cell chemistry. what he thinks he wants may not be it either.
I use this type of 12 volt battery. They can be daisy chained for more capacity..
Capacity DC 12V 4000mAH Rechargeable Lithium Li ion Battery Backup Power Bank For CCTV Camera MID GPS Tablet-in Rechargeable Batteries from Computer & Office on Aliexpress.com | Alibaba Group
Thanks Jesper, that clears up the battery chemistry thing quite a bit for me. So it sounds like Nimh is just not really the battery to use. Not a problem, I can pick up something else. I was just a bit overwhelmed by all the chemistry and dangers and charging protocols. So I just went with what I remembered from my RC kit days.
As Infinia says though, an SLA is not really ideal for this for me. For one, that battery would probably take up nearly half of the internal volume of my enclosure. So I'd have to rebuild it about 50% bigger. I really want this to stay pretty small so it can be used easily on my desk or the counter or put on a shelf. And this is built from hardwood so if it was much bigger, I'd have to do glue ups to get the wood wide enough. (BTW, I know all the issues with placing speakers on a shelf and using solid wood for the enclosure, but for a little BT speaker, none of that matters to me).
I think I might go with one of the LI-Ion batteries and either either run it only off of battery or figure out a smart charger that's also capable of running the modules too. I like that some of them have internal protection circuitry so regardless of the effect of the modules on the PS they are still at least minimally taken care of.
I have a couple of questions regarding the LI-Ions though. First, is balancing possible within the included protection IC? Or is this solely the function of the charger? Second, do they need a dedicated charger or a normal PS at the correct voltage and use the internal circuitry to handle charging. And can they be fast charged or are they trickle only? Are there any safety issues that I need to be concerned with regarding the LI's? I was originally looking at Lipo's but got scared away.
If I go with a battery powered only setup, what do you recommend for good capacity/price range so that I'm not charging it every couple of hours? A ballpark guess would be fine. I don't know the draw of all the components because all the BT/amp modules haven't gotten here yet, but I can't imagine the BT draws much, the amps are all 20w range mono chips with 80-90% efficiency and I'll have an led that draws 20ma/12v.
So the LI-ION batteries can be float charged without problems, but not stored at full charge, correct?
The intended use is mostly around the house, inside and out. I am fine with being mindful of the charging regimen, but my wife and kids will also use it and I can guarantee that trying to get them to do that will be a waste of breath.
- Chip Amps
- Battery power/power supply from wall charger for BT speaker
