ZD3 was broken and R40 became very hot.
After replacing ZD3, ZD4 R40 and R39 i measured the temperature with heat cam. R40 and R39 become very fast hot. About 120°C(250F).
Is that normal ?
I think the original ones were 5 watt resistors, length: 0.94 inch, diameter: 0.29 inch. 270Ohm.
The amp works fine, but i tested only for 20 min.
Is that normal ?
120C is quite comfortable for a power resistor.
Inn any case, besides thermal cam results, please post voltage at each end of each resistors.
Also, which ones ended staying on thyen PCB?
The greyish printed value ones or the whitish 3 colour band ones?
By the way, the top one does not look 270 ohm by any means.
But we need measured voltage values to calculate actual dissipation.
Thanks, that´s enough.The color has changed due to the enormous heat. It is still a 270 ohm resistor.
Across the resistor are 20V.
What voltages do you still need?
As Perry said, it´s dissipating WELL below ratings.
Not sure how the old one could have heated so much.
What´s the supply voltage in that amplifier?
Just to reach 5W, let alone surpass it, we need 36V across that resistor.
That´s why I asked for voltage at each end
- General Interest
- Car Audio
- Resistor getting very hot
