First time only Q6 was shorted between Base and Emitter.
4 Ohm bridge bench test passed.
During 2 Ohm bench test amp gone in protection near clipping point
This time Q6, Q5 and ZD6 failed.
Changed parts and during 4 Ohm bridge bench test amp gone again in protection.
This time only Q281 failed. N Channel Mosfet FQP33N10.
Both, Q281, Q181 changed. Set Bias and test it again.
Heat up amp with 8A Power consumption, clean sine wave, gain works properly.
After heating up, amp was a long time in idle current, maybe one hour. Remove remote, apply remote, Q6 again shorted between Base and Emitter.
Any idea?
Any idea?
No clean audio with bias fully counter clockwise and load(speaker). Plays audio but little noisy.
Without load I increase the gain up to clipping and measure the bias.
P Fet 2,2mV. N Fet 1,1mv. 2:1 ratio.
Picture is without load. Distortion are visible.
- General Interest
- Car Audio
- Audio System X 100.2
