You can defeat that undervolt error by lifting R127 from the board and installing a jumper wire from pin 8 of the PIC16 IC to pin 14. The amp will do one of two things. It will boot up, letting you know there is a problem with the undervolt circuit, or it will give you a different error code that is most likely the issue that is making the amp think it is in an undervolt condition. That’s what happens most of the time when I have to deal with an undervolt error in these amps.
I don’t have my notes in front of me because I’m out of my shop for a few days. They are 7.5v zenners and the small transistor is a general purpose npn BJT transistor (BC817) if memory serves me correctly.
I did post up some good working voltages for that area on this forum. I’ll try to find them and pull them over to this thread.
David
David
This is from some previous work I did on another amp.
I got lucky and got a Stetsom 8k into the shop that I just repaired and it’s working fine. So I took some voltage readings in the undervolt/overvolt circuit.
Feeding the amp 14.5 volts
D36 K 13.5v A 0.65v
D33 K 13.5v A 5.23v
D37 K .065v A .064v
D31 K 14.09v A 9.95v
D29 K 3.87v A .064v
D30 K .064v A .064v
Linear regulator 14.1 volts in and 5.05 volts out
Q27 B .067v E .771v C .064v
The emitter is connected to ground.
Test points next to the linear regulator
VPP .078v
PGD .075v
PGC 4.9v
VDD 5.0v
GND 0.0v
D36 K 13.5v A 0.65v
D33 K 13.5v A 5.23v
D37 K .065v A .064v
D29 K 3.87v A .064v
D30 K .064v A .064v
VPP .078v
PGD .075v
PGC 4.9v
VDD 5.0v
GND 0.0v
- General Interest
- Car Audio
- Stetsom
