It would take at least 2 open source resistors to stop it from biasing.
If a source resistor opened, there is a chance that the protection circuit was damaged. The low value resistors connected across the source resistors are the most likely to have failed.
Can you now bias the amp after replacing the source resistor?
- General Interest
- Car Audio
- Rockford Fosgate P300-1
