Drive at the gate resistor.
rhempz01 Member Joined 2016 2019-08-10 7:05 pm #41 2019-08-10 7:05 pm #41 Drive at the gate resistor. Attachments 15654601794623006435901896323993.jpg 870.7 KB · Views: 53 ••• More options Share rhempz01 Member Joined 2016 2019-08-10 7:20 pm #42 2019-08-10 7:20 pm #42 If i attempt to place a mosfet into the circuit current . ••• More options Share rhempz01 Member Joined 2016 2019-08-10 7:53 pm #43 2019-08-10 7:53 pm #43 I removed the rectifiers and installed just 4 mosfets. All banks work except for one that causes current and the fet gets red hot instantly. ••• More options Share rhempz01 Member Joined 2016 2019-08-10 8:39 pm #44 2019-08-10 8:39 pm #44 Drive on the bank that heats the fet. All regulated voltage is good, +-15,12,&5. What would cause one bank to heat up? Attachments 15654631887093069014573551733046.jpg 831.6 KB · Views: 52 ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2019-08-11 5:37 am #45 2019-08-11 5:37 am #45 There is no reason for that bank to be heating up (due to a drive fault) with the waveform you posted. ••• More options Share rhempz01 Member Joined 2016 2019-08-11 11:43 pm #46 2019-08-11 11:43 pm #46 Is 47r gate resistors ok? ••• More options Share rhempz01 Member Joined 2016 2019-08-11 11:45 pm #47 2019-08-11 11:45 pm #47 Drive with a capacitor in curcuit. Attachments 15655633932406546520393949839963.jpg 822.1 KB · Views: 45 ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2019-08-11 11:46 pm #48 2019-08-11 11:46 pm #48 Are you asking if 47 ohm gate resistors are OK to use in the amp? ••• More options Share rhempz01 Member Joined 2016 2019-08-12 1:50 pm #49 2019-08-12 1:50 pm #49 Yes, no matter what i try the amplifier will heat up the one side of fets. ••• More options Share T twilliar Member Joined 2019 2019-08-12 3:38 pm #50 2019-08-12 3:38 pm #50 With no rectifiers installed isolating the power supply, could there be a transformer short? I am thinking out loud, or short to ground. Not much can happen on these power supplies when it comes to failure points. The 47-ohm resistors are correct. ••• More options Share Prev 1 2 3 First Prev 3 of 3 Go to page Go Show hidden low quality content Status This old topic is closed. If you want to reopen this topic, contact a moderator using the "Report Post" button. Share: Facebook Twitter Reddit Pinterest Tumblr WhatsApp Email Share Link Home General Interest Car Audio Hifonics Brx2400.1d stuck in protection. Top Bottom
