I am new to the car audio world and I have just finished my first project. I installed two 12 inch subwoofers and an amp in my 2016 Camaro with Bose System. I'm now thinking I want to play around with adding tweeters behind the driver's seat (unpopular decision...Ik... but It would be cool to test). Anyway, I'm an idiot and bought a monoblock amplifier for my subs. It is an 1100 watt max amplifier with 825watt RMS @2ohm. See specs below.
Here is my question... what is the easiest/cheapest way to add two tweeters to my system. Is it possible to just use a passive component crossover and install it after the amp and connect the sub and tweeters to that? Or will that overpower the tweeters? Add another amp? Get a two channel amp? There is probably a better solution. Any ideas?
Amplifier:
https://www.amazon.com/Watts-Mosfet...&s=wireless&sprefix=boss+11,mobile,188&sr=1-1
Subs:
https://www.amazon.com/gp/product/B001JECAM2/ref=ppx_yo_dt_b_asin_title_o04_s01?ie=UTF8&psc=1
Amplifier:
Subs:
Hello Sai.
Congrats on your sound purchase, however, i would recomed you go for a 4 channel amp, 2 channels can be used for your subs and 2 channels for your tweeters.
the monoblock will work with your subs but the perfect recepie for dissaster is to connect tweeters to a monoblock.
tweeters dont present a huge load to an amp, so if you dont want to spendany more moola, u can experiment connecting the tweeters to the head unit direct.
You can't connect the tweeters at your new amp, because you must to set the low-pass crossover for your sub.I am new to the car audio world and I have just finished my first project. I installed two 12 inch subwoofers and an amp in my 2016 Camaro with Bose System. I'm now thinking I want to play around with adding tweeters behind the driver's seat (unpopular decision...Ik... but It would be cool to test). Anyway, I'm an idiot and bought a monoblock amplifier for my subs. It is an 1100 watt max amplifier with 825watt RMS @2ohm. See specs below.
Amplifier:
https://www.amazon.com/Watts-Mosfet-Monoblock-Amplifier-R1100M/dp/B004S4XNEO/ref=sr_1_1?crid=2RDUW5ARLFGE&keywords=boss+1100+watt+amp&qid=1562449893&s=wireless&sprefix=boss+11%2Cmobile%2C188&sr=1-1
Subs:
For to install the tweeters you need another amp.
You can take an amp with high-pass or it's possible to buy the tweeters with passive crossovers included.
