Quantum Audio QB2000D component id
I am looking for the id of 2 resistors R118 and R119. They are connected to the rectifiers on each side. These are burned and can't tell the value. Thanks
The voltage would be in the mv range. If the output stage is the problem, the current almost certainly has to be flowing through the output transistors.
If it's not clamped down, check the heating of the outputs to see if they're heating up.
A current limiting resistor typically works better than the limiter in a power supply.
