Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Thread Tools |
I'm not sure what is wrong with this amplifier, it Powers up and has a different curcuit than the cxa amplifiers. There is no output at the speaker terminals.
#2 |
Bottom board
#3 |
Top side
#4 |
Sub board 1
#5 |
Sub board 2 (Input)
#6 |
Boost converter, signal positive rail. The rail should be around ~80-85v. Also check the +/- 17 volts at Q22 and Q23 regulators.
Check to see if you have oscillation at both output coils L101 and L201 which should have a 50% duty cycle and ~80 volt swings. Use Power Ground for Black probe or scope Ground.
Any sufficiently advanced technology is indistinguishable from magic. Arthur C. Clarke |
#7 |
Q22-23 +-16.21vdc
L101 photo |
#8 |
L201
#9 |
The input board was badly damaged. Corrosion badly effected the components. I did the best I could to remove and rework the board. Same result, push 40hz 5v in and on the output jacks no signal? There maybe components missing.
#10 |
Your oscope pixs show a good amp, the input board is most certainly the problem.
The input board looks rough. Have you tried to signal trace through the input board? I will get pix of good input board and study schematic to see if your board has any missing parts. If you can get your hands on another KX8001, KX12001 or KX16001 any one of these amps uses the same input board.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Kicker kx800.4 opamp board help | rhempz01 | Car Audio | 31 | 31st July 2018 01:02 AM |
Kicker KX800.4 static | Deadly Sones | Car Audio | 35 | 14th February 2017 03:39 AM |
Kicker KX800.2 | crazyboi311 | Car Audio | 27 | 23rd May 2015 04:17 AM |
kicker kx800.4 stuck in protect mode | ivkata | Car Audio | 4 | 15th December 2011 02:28 AM |
kicker kx800.4 with bad irfz46n on the psu suitable replacement wanted | ivkata | Car Audio | 2 | 20th January 2011 01:40 AM |
New To Site? | Need Help? |
