Got a RF P300-2 that somehow, someone broke the metal shafts on the gain and freq selection (they still work). The are mounted on a riser board, parts number 1325-53110-02 (see pic). They say C20K on the back, one is a duel stack (gain) and the other is a quad stack with a spacer in the middle (freq select). getting ready to remove them to try and determine exactly what they are (linear, reverse, etc) but any help would be great (sean kane maybe). Would like to replace them, hate having a half arsed repair.
Getting the insulated shaft is tricky. The metal shafts are easy. I usually use those and paint them black.
The 2 gang 20k factory insulated shaft is part# PTD902-10BAP-B203
The 2 gang 20k metal shaft is part# PTD902-2215K-B203
The 4 gang 20k metal shaft is PTD904-2015K-A203
I do not have a part number for the 4 gang insulated shaft.
