US Amps AX-1500DE
Computer is down due to no internet .
So here’s a couple of pics I took with cell phone
0.1 cap across drain and source
Scope set to 2ms 2volta divide
These pics are of both banks .
Original fets were DFP70N06 with 47 ohm gate resistors
I replaced them with RFP70N06 with 47 ohm gate resistors
Sorry not sure why the pics flipped sideways
A couple of notes.
I'd suggest that you install that 0.1uf cap across the gate and source and look at the waveform. This is a good test for a drive circuit and you should know what the loaded waveform looks like. I think you can do this with the FETs in the circuit but if it looks like it's causing excessive current draw, do it on the next amp you repair the supply on.
I assumed that you had the scope set to the 'best initial setting' from page 73 of the site. That's why I initially didn't realize that the frequency was so low. There have been a lot of typos so I didn't really trust what was posted 100%, making some assumptions. When checking the PS waveforms, use 10uS. You would have immediately have caught the low frequency issue.
The reason I finally caught the low frequency was because the waveform wasn't distorted as much as I'd expect. I was going to post a waveform to show what you should see and that's when I remembered that you posted 2ms.
Also measure the frequency that it's operating at right now.
Post a photo of the audio section of the amp.
