Rockford Fosgate t1000-1bdcp no power
I just received a Rockford power series t1000-1bdcp and it has no power, doesn't draw any current. Don't see any protection lights at all. I do have 12.81vdc on the I/c and also on ps mosfets. So if anyone had a idea on what could possible be wrong with this amplifier, it would be much appreciated.
On that amp you can just hook up the ground and remote wire only, power the remote and check the power supply gate drive on the power supply fets. If you got drive on the fets, and you got power on the fets, you should be getting power out to the transformer (if it's not broken free) then out to the rectifiers. The fact that it draws no current at all tells me that its probably not developing power supply drive.
