Hello PerryIs there a reason that you believe the drive is defective?
The driver 2110 is in good condition.
The output signal that goes to the 264 is not clean at the moment of connecting the audio output transistors. And it produces a high-pitched noise that does not know where it originates
For those reasons I want to know how to measure the square wave output signal of the 2110 without connecting the 264 transistors
If you drive a 100hz signal into the amp, do you see the 100hz as a square wave on any of the outputs?
I can not make measurements with the 100hz tone.
Transistors take high temperature quickly.
Attached some images of measurements on the gate of the output transistors.
On pin 6 of IC172, do you have a triangle waveform?
Yes . The triangle waveform if it appears on pin 6, but with some distortion
Which waveform is from pin 7?
All of the above.
But the most stable is the following
- General Interest
- Car Audio
- KOLE TRAX 1.4000D not driver signal output 2110
