Rockford Fosgate M400-4 help
I have a Rockford m400-4 it has audio on 1 of the channels and none of the rest. Ps fets are all good. No shorts in any outputs. Didn't remove them to test them yet. I could use some ideas on what to look for. It has 3205's in the ps. And irfb4227 in the output stage of the amp.
I also have the same damaged amplifier ...
it is not normal for it to go down from 12.5 to 10.9v ..
Do you have a scope?
If you have it, can you check if it has a square waveform in the output gate pins of the fet in the audio channel that works?
check the same on the three remaining channels
Thank you for offering to help me, in my amplifier I am stuck at the point where I can not see square wave form outside the ps, and I do not know if it really is like this or not ..
Also, I think that pins 11 and 14 of IRS2092S should have a square shape, which I do not have, as in pin 4 I should have a triangular waveform, which I do not have either.
I do not know, I'm lost.
