PPI 2125 missing parts
Here's a pic of the board.
I don't have anything on any amps using that IC for a driver. The outline seems to indicate that they are a TO-220 case. If the center leg goes to a 12v source, they are likely NPN transistors. Possibly either 2N6488s or D44VH10s.
If this amp used FETs that were rated for significantly less current than the 3205s, the drive circuit may need to be modified to work with the 3205s.
Are you sure that the original PS transistors were FETs? This circuit has no gate resistors. The only time I can remember seeing that is when the supply used bipolar transistors.
