All JFET open-loop RIAA pre-amp
Old 19th May 2018, 05:29 PM   #31
EUVL is offline EUVL  Europe
Default Finally, the balanced version
Have been planning to build this for a few years now, and finally finishing this week.
Always want to build the balanced version only in order to get round the problem with low PSRR at the top rail.
Changes to the circuit are as follows :
+/-20V rails (battery powered, followered by 3x LM329, LP filtered to drive 5x BC327/337 follower in parallel)
Using 2SJ109 for 1st stage, 2SK389 for 2nd stage
2SJ109 is cascoded by 2x BC560C at -7V base voltage
R1,2,3,9,10 10k (Caddock MK132)
R5 2.5k nominal (2.7k S102//33k Beyschlag, fine trimmed for common mode DC)
Rv1 51R-51R//5k trimpot (for 1st stage differential DC)
R6,7 51R-51R//5k trimpot (for overall differential DC)
R4,C1 2.1k,147n (100n//47n)
R8,C2 880R,3.88n (887R//110k,2.2n//1n//680p)
After trimming, DC at the output before rumble filter is stable to within +/-5mV.
It is surprising stable considering the DC gain of 60dB.
A 10Hz rumble filter (15n/1M) was also added before the output followers, which are 2SK2145GR at 4mA.
The rumble filter will take care of any remaining DC after R9,10.
Gain at 1kHz is measured at 620x, which is as per expectation.
Still some final wiring to do.
Thanks for the nice and simple circuit.
Patrick
xen-audio.com
Old 19th May 2018, 07:32 PM   #32
Onvinyl is offline Onvinyl
Onvinyl's Avatar
Wow, only 13 years later
I like your 3-D-thinking!
Do you have a schematic?
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
Old 19th May 2018, 08:27 PM   #33
Simplified form.
Patrick
xen-audio.com
Old 20th May 2018, 04:28 AM   #34
Just noted a small typing mistake. R3 should be connected to -20V, and not +20V.
Patrick
xen-audio.com
Old 24th May 2018, 12:19 AM   #35
Ejam is offline Ejam  Australia
Default PDF Format
Patrick do you have the ASC file in PDF or JPEG format?
Old 24th May 2018, 04:43 AM   #36
Just download LTSpice.
It is free.
Patrick
xen-audio.com
All JFET open-loop RIAA pre-ampHide this!Advertise here!
JFET SRPP RIAA Preamp wrenchone Analogue Source 250 24th July 2015 08:32 PM
Open loop bandwidth in op-amp. beppe61 Solid State 94 1st October 2007 04:56 AM
BUF04 Open Loop Bonsai Solid State 0 7th August 2006 10:09 AM
Riaa Pacific Jfet maxpou Analogue Source 23 15th April 2006 05:51 PM
Op-amp open loop bandwidth. beppe61 Solid State 18 18th February 2005 02:30 PM
Copyright ©1999-2019 diyAudio
