Denon DP-11F - Platter always spins when unit powered on
Old 14th March 2020, 03:00 PM   #1
dmarley is offline dmarley
Default Denon DP-11F - Platter always spins when unit powered on
I have a Denon DP-11F turntable that I bought in the mid-80's and still use. It works but has developed a couple of 'quirks' presumably due to its age. In a nutshell, the platter spins constantly, any time the unit is powered up. This is a fully automatic turntable, so (if I am recalling correctly!) the platter is supposed to start spinning when the tonearm moves over the record, and stop when the tonearm returns to its cradle. Additionally, the tonearm does not automatically lift and return at the end of the record. The Start/Stop and Lift buttons all work fine. Seems to me like this might be a sensor that is no longer working, but....that's just a hunch, and a general one at that.
Neither of the issues are a show-stopper - I basically just use the turntable like you would a fully manual one. But I would like to return it to its original working order if possible.
Suggestions/thoughts on what the issue(s) might be? I know its not a high end turntable - there is some nostalgia attached to it, but if the cost to fix were too high I would probably opt to put that money into a new turntable.
Thanks in advance. Cheers.
Old 14th March 2020, 04:45 PM   #2
russc is online now russc  England
There is a service manual
Denon DP-11F - Manual - Fully-Automatic Microprocessor Control Turntable - Vinyl Engine
Old 14th March 2020, 06:09 PM   #3
Mark Tillotson is offline Mark Tillotson
There will probably be a microswitch to turn the motor on when the tonearm is in playing position, the oil/grease in the mechanism to operate the switch can get hard and dry with age, preventing the switch turning off. Certainly seen this with other make of TT.
Old 20th March 2020, 12:52 AM   #4
Thanks for the thoughts/suggestions. I did look at the service manual and nothing is jumping out at me as to where such a microswitch might be. But that definitely makes sense as a cause of this. I am going to try to open the unit up this weekend and see if I can find something that looks like it could be serving that function.
I'll report back if I find anything. Thanks again!
Old 20th March 2020, 03:31 AM   #5
davidsrsb is offline davidsrsb  Malaysia
Apart from the microswitch suggestion, another possible cause would be capacitors across the power switch failing short
Old 1st April 2020, 01:05 AM   #6
Thanks davidsrsb. That sounds like something that would be outside my skills to troubleshoot, but its good to know nonetheless.
I haven't had a chance to open up my unit and look for a suspect microswitch, but I will report back here once I do.
Denon DP-11F - Platter always spins when unit powered onHide this!Advertise here!
WTB: Battery powered O2 + odac rev b combo unit RetroR Swap Meet 0 16th October 2016 05:51 AM
WTB: DENON AVR-3300 AUDIO/DSP unit Junie Swap Meet 0 11th November 2011 03:34 AM
Help! CD platter just spins after changing op amp on Denon player... bermtoog Digital Source 8 14th April 2011 06:20 AM
denon head unit, no remote turn on? an2ny888 Car Audio 3 24th October 2008 08:56 AM
Denon DP-47F platter scratches Gregory Isaacs Analogue Source 0 13th December 2007 04:39 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
