Hi. I think I've already asked this question, but I can not find the link.
I have a Marantz PM6006 integrated amplifier, with integrated phono stage.
I have built several phono kits and I have seen several phono pre circuits from other manufacturers, but I have never seen this MM cartridge load configuration that the Marantz PM6006 has (the value of the choke is not specified).
My question is how this load configuration interacts with the cartridge (AT440MLb, 490mH and 3200 ohms).
I appreciate if someone who is knowledgeable in this topic can explain it.
Of course I have disarmed the Marantz to get photos.
Okay. Thanks, but I see a resistor of 330k after the choke, instead of the traditional 47k as charge.
This is very common when the input stage is bipolar and it is essential to have a dc blocking cap - the 47k is split in two.
> It is certainly 320µH
Which is "nothing" compared to Alpuy's 490mH pickup.
And is only 40 Ohms at 20KHz, so no effect in a 47K circuit.
With the 200pFd present, 320uH resonates at 630KHz, and will fall 12dB through the broadcast band and beyond. As you say, an RF filter.
Anyway that doughnut is too darn small to do anything to a high impedance audio circuit.
AT440MLb
Coil impedance : 3,200 ohms at 1 kHz
DC resistance : 800
Load Capacitance : 100-200pF
Coil inductance (mH, 1 kHz) : 490
Dynamic compliance (x10-6 cm/dyne) : 10
Static compliance (x10-6 cm/dyne) : 40
Vertical tracking angle : 20-degree
Dimensions (mm) : H 17.3 x W 16.0 x D 28.2
Weight (g) : 6.5
Frequency Response 20-25,000 Hz
Channel Separation 28 (dB at 1 kHz)
Tracking Force Range 1.0-1.8 grams (1.4 optimal)
Stylus Construction 0.12 mil Nude
square Micro-Linear
stylus
Recommended Load Impedance 47,000 ohms
Output 4.0 (mV, 1 kHz, 5 cm/sec)
Channel Balance 1.0 (dB at 1 KHz)
Stylus Shape MicroLine®
Cantilever Aluminum Pipe
Mount Half-inch
Replacement Stylus ATN440M
DC resistance : 800
Weight (g) : 6.5
square Micro-Linear
stylus
Mount Half-inch
I see when simulating in LTSpice, an important fall between 10khz and 20khz (approximately to 11 dB).
I would say that more than 400 pF of capacitive load is a more likely reason.
You should try removing C4001 from the simulation as a start - and also from the amplifier, to check if you hear the change in sound.
From my personal experience - capacitive load 200 pF vs 400 pF is audible.
... and then remove them from the circuit.
Probably it would be better to leave at least 100 pF on the phono input - you can add capacitance later on e.g. with (diy) capacitance load plugs.
- Analogue Source
- Phono preamplifier load
