I'm looking to get a tonearm for an early Transcriptor Saturn turntable.
The image attached shows the mounting holes (7/8" and 6/8", center to center).
I think that the turntable came with the Vestigial tonearm initially, and the previous owner probably drilled holes for another arm.
Can you please suggest a decent tonearm that would fit?
Thank you!
Thank you!
The pivot-stylus distance is 222mm, so many arms could work, including the Grace 707 and similar.
