Solid State Phono Pre-Amplifier with RIAA LCR Network - Overview wanted
View attachment Rolls Corp. Pre Amp.pdf
All copyrights are with the creators, I just downloaded them, and posted here to save others the effort.
Built one with opamps a few years ago. Used Lundahl iron. It was easy to compare RC vs LR vs LCR in the same setup. LCR won by a significant margin and is by far the best opamp riaa i have ever heard. In many respects it sounds better to me than all my valve attempts. Individual shunt regs for each opamp, but nothing else that is special. No coupling caps by virtue of low offset opamps. The Lundahl parts, perhaps unsurprisingly, were way off their stated values, so resistors had to be tweaked but in the end got about 0.2db accuracy.
Sorry, what spam?
When I was planning a phono pre amp. I had downloaded these, they were in storage on my computer.
To save others the trouble I put them up, then I realized that these were without coils.
I did say that I have no connection with the designers, so how would I gain by posting these circuits?
Spam is done with some gain in mind, monetary or otherwise.
I did post something not quite relevant, that is all.
And I did suggest a source for the coils, which can be a problem to find.
Once again, apologies for any offence caused...
