Valve Itch phono
Valve Itch phono
Old 29th July 2017, 06:09 PM   #3051
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Valve Itch phono
Originally Posted by merlin el mago View Post
Alright
Old 29th July 2017, 06:11 PM   #3052
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Time to listen with 0,1uF interstage capacitor.
Old 29th July 2017, 06:18 PM   #3053
Salas's Avatar
Valve Itch phono
Yes, that one too. To be listening "by the book" first.
P.S. You put 1R one after the other until with four of them RAW Vin dropped to 9VDC? There is 3R9 value to get and finally install if so.
Old 29th July 2017, 07:55 PM   #3054
No, only one 4 ohms resistor. Fortunately I have 1R and 4R both Caddock mp915, 15w using box as heat sink.
Old 29th July 2017, 07:59 PM   #3055
Now the mids and bass are ok, perhaps I will have to take off the 330pF added to the 15nF RIAA used to reduce the extra highs....
Old 29th July 2017, 08:27 PM   #3056
Salas's Avatar
Valve Itch phono
15nF+ reduces HF. 15nF- boosts HF. V1.2 schematic has 15.75nF HF RIAA cap and 2.2uF output cap. That one had a certain SUT and TT to align with so trimming to your own HF cap value sweet spot is normal.
Old 8th December 2017, 10:14 AM   #3057
Salas can be enough 100uF + 100uF in place of 220uF + 220uF as mains filter caps?
Old 8th December 2017, 10:53 AM   #3058
Salas's Avatar
Valve Itch phono
Possibly
Old 8th December 2017, 12:20 PM   #3059
Thanks, I will try.
Old 8th December 2017, 01:17 PM   #3060
Removed the Elna Cerafine 220uF+220uF 350V and changed for Rubycon Black Gate 100uF+100uF 350V and the difference in SQ is very big.
Valve Itch phonoHide this!Advertise here!
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 26th September 2008 11:49 PM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 08:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 04:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 02:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 02:12 PM
