Preamp Oscillation problems - Suggestions?
Joined 2014
I've just completed a couple preamp boards by Greg Ball - called the SKA Pre. Each channel is on a separate board. One board works fine. The other seems to be oscillating at about 14MHz but only with the input shorted. In other words, with the volume potentiometer turned for minimum (i.e. input connected to ground) the oscillation is at its maximum. As the volume potentiometer is turned up, the oscillation disappears. Attached is the schematic. Any suggestions will be appreciated.
  • SKA Pre schematic.pdf
