Single ended preamplifier bias
Thread Tools
Old 27th March 2021, 09:48 PM   #1
wersuss is offline wersuss
Default Single ended preamplifier bias
Hello, i have preamp and would like to make sure everything is in working order. Anyone knows where to measure transistors and how to adjust their offset with trimmers? Because one runs 38c and rest 33-34c
These are Toshiba 2SC2238Y/ 2SA968Y.
Old 2nd April 2021, 10:52 PM   #2
ejp is offline ejp  Australia
You don't adjust their offset at all.
Old 3rd April 2021, 01:10 PM   #3
Thank you for absw. What those trim pots do here then? What about current adjust?
Old 3rd April 2021, 08:54 PM   #4
Impossible to say from just a photo. Do you have a service manual? Schematic?
Old 3rd April 2021, 08:58 PM   #5
rayma is offline rayma  United States
It's likely they are for adjusting the regulator voltages to an exact value.
Perhaps 15VDC, but check the mfr info first. If the board was supplied assembled,
the adjustments should already have been made.
Old 4th April 2021, 02:00 PM   #6
I have tried to turn them and watch transistors temperature so voltage regulators will be off. Where can i measure voltage? The original board looked like this
Old 5th April 2021, 08:57 PM   #7
Can it be DC offset for op amps? i measured voltages at trim pots are around 200mV.
Old 5th April 2021, 10:43 PM   #8
That's the total available control voltage for whatever is being controlled, not the DC offset. No opamp is going to have that much DC offset in any sane preamp circuit. You need to abandon this theory or else back it up with a schematic. If you can't produce a schematic it's difficult to see the point of this thread.
Old 5th April 2021, 11:07 PM   #9
True hehe. Well it sounds good so i will just leave it, no schematic. But before left channel had small noise while controlling volume and now when i adjusted all 4 resistors to same 0.25v that noise is gone.
Old 8th April 2021, 03:36 PM   #10
andy2 is offline andy2  United States
It seems like your pre is an opamp based amplifier. Which opamp did you used and how does it sound?
Single ended preamplifier biasHide this!Advertise here!
Thread Tools
Single tube, Single ended, 20W, impossible? dannydanger Tubes / Valves 44 19th November 2020 11:40 PM
Single High power Mosfet for big Single Ended Amp ? Ado Solid State 20 25th February 2016 03:32 AM
Single Ended, Single driver: In-room distortion measurements Gerrit Boers Full Range 4 27th November 2007 08:12 AM
Anyone play with the Zen Single-Stage Single-Ended Class A? Rino odorico Pass Labs 13 29th August 2002 09:01 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
