Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Thread Tools |
Hi everybody... First of all, please forgive my bad english...
I would ask advice about a nasty hum problem I have from a 4 channels B1 buffer with two Biino volume control boards I built... I tried various wiring ways to improve but none worked... The situation now is what (maybe) you can see from the weird drawing here... Can you see something absolutely wrong that could cause gnd loops or something? I used a gnd loop breaker between psu star ground and earth/chassis... Thank you so much! PS. The Biino is a relay attenuator you can see here: Biino MK2 – hifi-electronics.de Last edited by Porfido; Yesterday at 09:47 PM. |
#2 |
Should I maybe try disconnecting psu star from signal?
#3 |
A photo would help .
#4 |
Thank you! Here some images before some modifications I made to wiring...
#5 |
Would you post a photo of the current setup taken from directly overhead . There are a lot of white wires to trace .
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
WTB: Remote Control Module for TVC (Volume Control + Input Control) | lordvader | DIY HiFi Supply | 0 | 17th February 2021 11:26 PM |
Noise from a 4 channel B1 buffer with Biino MK2 volume control... | Porfido | Analog Line Level | 0 | 13th April 2020 04:33 PM |
Biino Mk2 | thimios | Analog Line Level | 10 | 3rd November 2019 08:32 AM |
Replacing broken volume control with digital volume control | Gunawan W | Solid State | 19 | 15th December 2010 11:46 AM |
Improved PSU for Technics SL1210 MK2 and SP 10 MK2 (and others) | beetle | Analogue Source | 21 | 20th January 2010 12:25 AM |
New To Site? | Need Help? |
