reduce Electrocompaniet EC 4 Gain
Old 25th March 2020, 11:38 AM   #11
blek stena is offline blek stena  Croatia
Amount of feedback does affect gain but at the same time also output impedance, harmonic distribution, bandwidth...
Old 25th March 2020, 11:44 AM   #12
Depaj is offline Depaj  France
Hmm I see. I tested for bandwidth between unmodified and modified channel, no changes whatsoever there but I don't have anything to test harmonics.
Old 25th March 2020, 11:49 AM   #13
In your case the bandwidth change shouldn't have significant effect.
But who knows maybe you get the sound you will like more than you had with unmodified preamp:-)
Old 25th March 2020, 11:52 AM   #14
I loved the sound before and don't really want to change it. I just read some articles about it being also a probable cause for instability, maybe this wasn't such a great solution (although it seems stable to me).
Old 25th March 2020, 11:59 AM   #15
You can still try to attenuate the signal at AW60 input. Listen to both solutions and decide which one you like best.
Regarding the oscillations: the problem is that in most cases you will not detect them by ear because they occur at high frequencies. Far beyond from what our ears can detect.
Old 25th March 2020, 12:07 PM   #16
I checked for oscillations by scope on a square wave as well as on a very high frequency on a regular sine wave, they both look perfectly clear of any oscillation.
Old 25th March 2020, 12:10 PM   #17
You should be OK then.
  Reply to this post
reduce Electrocompaniet EC 4 GainHide this!Advertise here!
How to reduce a DAC gain LoneL Digital Line Level 3 24th May 2017 06:27 AM
How to reduce dac output gain? dacster Digital Source 12 1st June 2015 05:06 PM
What's the Best Way to Reduce Gain in a Preamp rcollege Tubes / Valves 14 23rd April 2014 07:25 PM
How to reduce the gain of the symasym 5_3? formula 22 Solid State 0 20th September 2011 04:13 PM
Electrocompaniet AW-250r Gain maxzimum Solid State 6 4th January 2009 07:05 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
