Single touch EQ on/off switch with IQS127D
Single touch EQ on/off switch with IQS127D Please consider donating to help us continue to serve you.
Old 20th November 2019, 09:08 PM   #1
Hicoco is offline Hicoco  France
Default Single touch EQ on/off switch with IQS127D
Did somebody use the IQS127D, Single Channel Capacitive Proximity/Touch Controller?
I need some advise, i would like to be sure that i will calculate the right value Rb value for the BC327 of my switching circuit. I am little confused with the Datasheet, IQS127D sink current for Tout is 1mA and for Pout 3mA, is that correct?
Every DIYer need Balanced-Unbalanced Audio Input Selector Module
Old 20th November 2019, 09:34 PM   #2
PRR is offline PRR  United States
PRR's Avatar
Yes, it is odd the P and T outputs have different max ratings.
More important: what LOAD is the BC327 expected to drive? You need more than enough base current to saturate the BC327 into the load it drives. I don't have BC327 specs memorized, and I have no idea what your load is.
Old 20th November 2019, 09:41 PM   #3
Thank, PRR.
My load is a EC2-5NU 178ohm 28mA. so if 1mA is correct. 5k should be enought to saturate the BC327
Old 21st November 2019, 03:29 AM   #4
PRR's Avatar
OK.
Single touch EQ on/off switch with IQS127DHide this!Advertise here!
Single touch power on/off switch Shamron Power Supplies 21 17th December 2019 05:55 PM
Soft-touch keypad membrane switch repair tsmith1315 The Lounge 8 5th June 2019 09:48 PM
Touch interface switch and remote Alexontherocks Construction Tips 1 31st January 2012 10:45 AM
FS: OLED Displays / Capacitive Touch Screens / Multi-touch ICs & More promixe Swap Meet 1 11th May 2011 11:15 PM
touch button power switch circuit vossie Pass Labs 17 23rd September 2003 07:31 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
