I’m building the the above kit and need some help determining which values to use as the manual does not specify.
R12a and R12b - I have 6 pairs of resistors (1.6, 2k, 3k, 3.9k, 6.8k, and 10k).
R17 - 300,1K, 10k (5w), and 100 (3w)
I’m using a Hammond 270CAX and will be using all 12au7s (same build as tubecad.com.
Pics below.
Pics below.
Somewhere near the end of the manual you should find a table with a bunch of suggested values for different tubes.
There should be suggested values for a 12AU7 at a b+ of 300v(?).
There should also be a table and some formulae if you are willing to do the maths to work out the value out.
I've not built an all in one aikido nor have I seen the manual for it so I can only work based off what information I have at my end.
