Stereo Speaker Level to Line Level Signal Question
I want to use HiFi receiver speaker level output to create a line level signal. I have an HK 3390 with pre-outs but when used, the 2nd set of speakers
stop working. I want to get a miniDSP so that I can bi-amp the front speakers. I am sure this has been discussed and explained before but I could not find all of the details. I could purchase a Russound ADP-1.2 for $40 but it looks like it only uses a few resistors that are inexpensive. After many searches I uncovered the following layout - see attached doc #1. I also am including a closeup of the Russound ADP-1.2 - doc #2.
Can anyone with more of a electronics background validate my approach or correct it?
  • Doc #1.pdf
  • Doc #2.pdf
PRR
Joined 2003
> HK 3390 with pre-outs but when used, the 2nd set of speakers stop working.
Are you removing the jumpers? As instructed (attached)?
What you want is RCA Y-cables, M-F-M. Use the two male ends like those jumpers, to patch signal back into the box. Plug the external system into the female connector on the Y-cable. This may be mildly sensitive to loading- the PreOut comes from wipers of pots and will be low-Z when BAL pot is centered but up to 13K one side half down.
Yes, the 3390 speaker outlets are hard grounded on the black screws so the diver networks you show should work.
