Passive preamp introduces hum
I must be too stupid for DIY...
I made a small passive preamp (just an alps in a box), but when I connect it to a small digital amp for testing, an audible hum is introduced to the otherwise fine signal. The hum does not appear when the volume is either at zero or at max volume, so only when the wiper is on the track.
Wiring is as follows:
The alps takes input from two RCA's, and sends the signals out to two RCA's as well.
The returns of the RCA's are wired to the ground pin of the Alps, the IN signal wires to the IN pin and the wipers are wired to the signal of the OUT RCA's.
IMG_9617 by ctjr, on Flickr
Each input is a two wire pair.
You must take two wires from the input socket to the vol pot for each input
Each output is a two wire pair.
You must take two wires from the vol pot to the output socket.
Those two wire pairs need to be close coupled along their whole route from source to receiver. Use either coaxial cable, or utp (Unshielded twisted pair), or stp (shielded twisted pair). The screen of the coaxial is the Signal It must not be connected to the metal case/chassis. The screen of the STP must be connected to the case/chassis at both ends. The metal parts (that are not the signal) of the vol pot should also be connected to the case/chassis
At the RCA sockets I can see a BIG gap between the Signal Flow (white, or red) and the Signal Return (black). Those BIG gaps are susceptable to picking up interference.
You need to keep the Return VERY close to the Flow to minimise the gap and thus minimise the interference.
The Alps does not have a "ground" pin.
It has a pin that is common to both the input and to the output. That common sees two wires, one coming from the input socket and one going to the output socket. It is not ground. It does not get connected to ground, nor to the case/chassis.
There'll be common-mode currents at mains frequency running along the interconnects. This renders the local 0V reference (at the pot) noisy with hum compared to the 0V at the amp input. When the volume's not at max or min, the quality of this local 0V matters.
Well... that's outrageously expensive. I bought this Alps because the maker of my amp (audiosector Gainclone) recommend just a pot as volume control. I had to build it outside the case of my amp for convenience and so I could use the amp as a separate in a MiniDSP system.
Are your RCA's grounded to the case, or isolated?
nash
The case is plastic, so the case can't function as a ground.
I tried twisting the wires and soldering them directly to the RCA instead of connecting them to the tab. This made no difference at all.
What still puzzles me, is that there is only hum when the pot is between either ends; at maximum "volume" (i.e. turned fully open) the hum disappears.
