zenv4 trouble
Good evening all,
I made a stupid mistake while changing to new rectifier:I reversed the voltage coming from supply.the fuse was blowing.Ater that one chanell is stil working like he should,but the other doesnt sing anymore.I messured some voltages,started with q5.unregulated voltage in at the drain is fine-around 49v,but then nothing on gate and source.I changed Q5... same as before.i moved of d1... same as b.
Anyone,would be so kind and give me a direction to proceed?
Thanks in advance.
small children around, so time is like gold...
