Zaph Audio SR-71 build
Hello!
I am going to build Zaph Audio SR-71. Recommended Madisound’s baffle is 1” width, back and sides are 3/4”.
It’s difficult for me to make 1” front baffle due to technical reasons (and price is increasing). I can cut 3/4” MDF board in one cycle.
Is it ok to use 3/4” as front baffle? This will reduce depth of cabinet by 1/4” (or about 6,5 mm), and reduce stiffness of front baffle. But does it is sacrifice overall system performance? Is there an impact on tonal balance (baffle dimemtions stays the same)?
http://zaphaudio.com/SR71.pdf - you can find cabinet drawing here.
English is not my native, sorry. I hope you’ve understand a question. DIY-ers experienced with Zaph Audio SR-71 are always welcome! Thanks a lot.
I used the knockdown cabinet from Parts express, 0.56 cabinet. And countersunk the drivers. Very Nice speakers for the price.
I use them in my bedroom system mainly for tv and movies.
The knockdown cabinets from Parts express made things so easy. I doubt I could make them for the price I paid. I don't work there or anything just sayin.
What counts is baffle dimension and internal volume. If I understand correctly you won't change them.
IMHO a 3/4" baffle for your kind of speaker is doable, but a 1" thickness would be better, you could simply glue a 6mm MDF foil over the 3/4" baffle.
Ralf
