Hi. I've picked up some of the blue yuan jing 3116 boards for an embedded project and I'm a total newb who couldn't find a simple answer to how to add a volume control pot to this thing. Would greatly appreciate it if someone could enlighten me.
So I take it I need a 50k audio taper pot per the wiki? Do I need to insert it into the existing circuit somewhere or can I taper the input voltage to the board or the input audio signal?
I'm also wondering if 24V will work okay for supply. I've heard on here that 19V is the sweet spot. I just need the thing to run okay without clipping. Is the difference really significant?
Many thanks
Many thanks
The gain cant be regulated by a pot.... If you mean for the volume, check in Google there many places that explains how to do it...
Okay thank you. I've looked and I can't find a simple wiring diagram for this board.
