Your free test tone CD
Here's a test tone CD I just made, MP3 file format.
6 zipped tracks in a self extractor.
10 minutes for each sine wave track. Each have an amplitude of 0 dB's.
Scroll down, click Download for free with FileFactory Basic, type in your verification code and receive your test tone CD.
http://www.filefactory.com/dlf/f/3d1810/b/3/h/a9b45b656afb2804/j/1170969825
When you burn it, first track should be 1000 hz sine wave.
Then 25, 50, 80, 120 and 180 for your bass tuning. You're best listening through them and deciding which has the feel you're looking for and sounds best on your system then using that pitch to tune your sub.
Don't know how to use it?
Set your head unit at 75%-85% volume. Set your amps output to it's minimum level. Gradually turn up your amp until you hear the 1000 Hz sine wave start to clip(distort) then back it off a tiny bit.
You're all done.
After this is done, you can move onto the bass tuning if required.
First decide which frequency you want to set your crossover for after going through the test tones.
Adjust your frequency control to that desired frequency. Again, turn up the bass gain until your amp starts to clip(distort) then back it off a tiny bit.
You're done.
