YBA Passion 300
Hi to ALL. - i have a problem with input selector, i buy it used - and when it's come i found that input selector button is not firmly sit in place and i can
reeling it for about 2 or 3 mm in any directions.. and it misses a click when i change input source - but it's working..
I open YBA and found that PCB where input selector mounted reeling also for about 1-2mm from the only side where input selector located - from other side where volume control - it sits firmly..
I tried to remove front aluminium panel - unscrew 2 bolts - but no luck it firmly sits in place.. - can you help me please - how i can see whats the problem ? how remove front panel ??
Thanks.
