Yamaha rx-v373 making me pull my hair out!
I actually had like 10 of these with the same problem. I was able to fix a couple by changing the chicklet caps in the power supply. Strange thing was the tested good on my cap meter.
I may still have parts around if you need some, have to check, I scrapped about 40 receivers the other day. Tired of messing with them.
The first thing I would check it is that you have the 9.3 volts page 89. Second if it is OKAY then I will check the PWR_RY signal. That will enable the relay RYI-51 that close the contact that applied the AC power to the main transformer.
